Discuss Extending cables in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
These connectors are fine for being used as connections within junction boxes and the like. Used in a CU or DB to extend circuit conductors and would look as if a DIY'er had been at work whether they are electrically safe or not. NO nothing better than good in-line crimped joints as i described above, if you want your installation to look professional....
TBH I just do whatever I feel is most suitable at the time.
But Geordie and E54, you have gotten through to me so next time I need to extend a cable in a CU I'll still do what I've always done but will now have a slight twinge of guilt if I use an in line connector.
At the very least I'll have a little smile to myself about two fussy old codgers shaking their virtual heads at my DIY bodgery.
What can i say, ....from what i can make out here, it'll take too long, it'll add additional costs in both material and time, or just why bother!! It's the time of the new age electrician i'm afraid, where doing things properly comes in at a distant second place to cost cutting and Easy!! ...lol!!
I've also used the ideal inline connectors and they failed. I returned them and told the wholesaler. I've also seen the other ideal connectors fail.
It's company policy where is work to use themI've also used the ideal inline connectors and they failed. I returned them and told the wholesaler. I've also seen the other ideal connectors fail.
Does this scenario relate to a CU swap? if the cables are to short to make a decent job then why not install a din rail enclosure adjacent to the CU and make a decent job of extending all the cables.
Yes Eng you are probably correct, shame really don't you think.
That's why were considered to be Dinosaurs on here Pete!! You can just imagine what sort of trainee's these couldn't care less electricians turn out.....
And now low and behold, we're hearing about these Ideal through joints failing. but i guess they won't have any of it!!
In fairness I've never had an issue with them but the number I've installed is nowhere near a big enough sample size to draw any knid of conclusion.
I'd be very interested to see what issues others have had and whether or not the conductors were straight and clean when the connectors were used.
I had issues with a handful of Wago lever connectors a while back and now don't trust them but thousands of others would disagree.
Reply to Extending cables in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
