Extending/Moving Ceiling Rose/Pendant between floor joists ? | on ElectriciansForums
Discuss Extending/Moving Ceiling Rose/Pendant between floor joists ? in the UK Electrical Forum area at ElectriciansForums.net
Birmingham
Hi All.
I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to the ceiling joist and then run 3 core 0.75mm flex through the plasterboard ceiling to the light fitting. Or, do I have to extend all three 1.5mm T&E cables in MF junction box, and then connect 3 core 0.75mm flex out of ceiling to light fitting ?
Unfortunately all the rooms haves laminate flooring, except the one where I have access.
Any advice will be kindly appreciated.
Reply to Extending/Moving Ceiling Rose/Pendant between floor joists ? in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
