Extending ring circuit | Page 2 | on ElectriciansForums
Discuss Extending ring circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Screwfix have gaping holes in their catalogue .........
Must have been a glitch somewhere then Mate, when I worked for them the stock control was very good.
The OP intends extending the ring, not spuring off from the ring.
I would use crimps in the back box.
If the OP spurred from the nearest socket outlet, then he wouldn't need to crimp anything!
Ok, I must have my thick head on today.
Why, if you can get to the back box of the socket not just extend from the socket itself?
First time doing this...spurred of before but im a heavy user. I could use heaters which are power hungry. Also i run alot of computer equipment for work purposes 24/7. i think it would be better suited to extend ring given that it would take same amount of work.
I think I'll go with crimp, finally unpack my brand new crimper
Plus I'm a cheapskate.
If they are the standard red/blue/yellow crimps, they are not designed for use on solid conductors and do not provide any guarantee of a good, long lasting connection.
For solid cores you should be using uninsulated indent crimps and then the necessary good quality heatshrink sleeving to insulate them.
For extending rings in back boxes I find the Ideal in-line splices are fantastic...
https://www.screwfix.com/p/ideal-spliceline-in-line-wire-connectors-pack-of-10/42201
It’s not stock control, it’s whats on the shelf in the local stores ...... not in the central stores
Stock control in the Screwfix outlets are controlled, updated on a daily basis, from personal experience, I can vouch for their product maintainability.
https://www.screwfix.com/p/ideal-in-sure-2-port-push-in-wire-connectors-pack-of-100/50427
Are these any good?
Or these...
https://www.screwfix.com/p/ideal-in-sure-3-port-push-in-wire-connectors-pack-of-100/56118
Last time I checked, there were many crimp manufacturers that state their crimps are suitable for solid conductors.
I wouldn't use them due to the nature of the crimp construction. As you know, typically they are a split tube which is simply pressed into an oval shape when crimped. Usually it's quite a thin wall on the tube and I'm just not convinced they stand up well to the thermal cycling they may experience.
I've certainly tried a variety of crimps on solid cable in the past and not had much joy (various crimp manufacturers and various crimp tools), and I've pulled far too many apart with very little effort that have been installed on sites I've worked on, so I just steer clear and use things like the SpliceLine and Wagos.
Reply to Extending ring circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I thought I'd add a few photo's of the overall situation we find ourselves in and the general standard of the building work, which is why going...
An example of the long term race to the bottom of quality of work in our industry, IMHO.
