Extending ring circuit | Page 3 | on ElectriciansForums
Discuss Extending ring circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I wouldn't use them due to the nature of the crimp construction. As you know, typically they are a split tube which is simply pressed into an oval shape when crimped. Usually it's quite a thin wall on the tube and I'm just not convinced they stand up well to the thermal cycling they may experience.
I've certainly tried a variety of crimps on solid cable in the past and not had much joy (various crimp manufacturers and various crimp tools), and I've pulled far too many apart with very little effort that have been installed on sites I've worked on, so I just steer clear and use things like the SpliceLine and Wagos.
The red, blue and yellow crimps are usually barrel type, with a thin wall solid tube inside a thicker wall split tube.
Stock control in the Screwfix outlets are controlled, updated on a daily basis, from personal experience, I can vouch for their product maintainability.
I needed some piranha's last week - NONE of the local stores had stock and ALL had them on "over night" delivery........
I've not seen any like that. The one's I've seen have always been the split tube is the main inner.
Would you mind pointing me in the direction of that style please?
Company called AMP.
Although saying that it appears some of my crimps do not have the extra tube.
Crimp pak and Engex, don’t.
I think the extra tube ones are called ‘faston’.
Reply to Extending ring circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I thought I'd add a few photo's of the overall situation we find ourselves in and the general standard of the building work, which is why going...
An example of the long term race to the bottom of quality of work in our industry, IMHO.
