Exterior lighting | on ElectriciansForums
Discuss Exterior lighting in the UK Electrical Forum area at ElectriciansForums.net
Gringoking88
London
Hi all,
I have been asked to swap an exterior tube lighting thing to 4 wall lights over a shop front for a friend. My question is what would you guys use for the neatest and tidiest way of splitting the cables e.g. From light 1 to light 2 etc etc? I cant do inside the light fitting as they just have a rubber gromit that would only maintain a seal around 1 individual round cable? I am reluctant to use adaptable boxes as they are so big and ugly.
Any advise or ideas would be great???
Many thanks,
Martin
What lights are you thinking of using?
What cable size is currently used for the light?
What fuse size is protecting the cable?
Tend to pop external LED lighting connections in a Wiska box here, you can get them fairly small. Not sure if that's the sort of thing you had in mind?
30 Amp Wiska Junction Box 85 x 85 x 51mm - Black IP66 - https://www.tlc-direct.co.uk/Products/WK308B.html
Hi Hightower,
I was hoping for something a bit smaller than that, something that could be used almost inline. The lights are going in a line over a length of wall so using that would mean having to run 4 wires from the box for the entire length.
Hi Westward,
On the back of the cable entry (base of the light) their is a simple rubber grommet used to maintain ip rating, dont think it would be big enough to put two cables in through and if I did definitely wouldn't maintain rating or it would just split.
Sorry not clear, I meant split inside the building.
No problem, I could but no need really. I could get away with having one junction box at the beginning of the 4 lights but what I want to do is run them 1 after the other. I have tried to show what I mean in the attached pic
[ElectriciansForums.net] Exterior lighting
Don't bother using the grommit, just seal the entry after both cables have been entered using a bit silicone. I've actually installed lights (can't remember make but decent quality) that don't even provide a grommit and the MI say to use silicone sealant.
I would personally avoid the external junction box. Put it inside and run four cables to each light or if possible run pvc conduit internally and connect at through boxes using Wagos.
Westward,
The silicone sealing idea made my brain tick lol, so have been doing a bit of reading, have you ever used magic gel as this would seem the perfect solution!!!
Reply to Exterior lighting in the UK Electrical Forum area at ElectriciansForums.net
I've made the required tweaks on the junction box with a 4mm hole bottom, upturned wagos and reduced the exposed copper. I did originally install...
