External cable runs | on ElectriciansForums
Discuss External cable runs in the Australia area at ElectriciansForums.net
Tony Way
Cambridgshire
Hi Guys
I seem to do a lot of retrofit external lights to properties where they don't want damaged walls inside. So, only way to do it is to run cables externally. Now as we all know, you're not allowed to run 6242Y outside without protection from UV etc. So obvious options are: to run it in round conduit (but terminations via terminal boxes etc don't look too pretty) use SWA, but very few fittings allow direct termination.
Can you use HITUF / NYY-J (i guess if you could there similar issues to SWA), or is there anything else out there that looks better, speeds installation and eases termintion into domestic style external fittings?
Many thanks
Tony
I use black rubber or PVC flex, appropriately sized and clipped into the mortar seams. Rubber is more UV stable than PVC so better if it's going to be in direct sunlight.
IMO black flex [visually] melts into the wall far better than conduit. Also try to keep it out of direct 'eye line', especially horizontal runs.
Hi guys, just to ressurect this thread instead of starting another, in a weeks time i need to supply an outbuilding via a 3 metre catenary wire. What cable type would you guys suggest for this?
Reply to External cable runs in the Australia area at ElectriciansForums.net
