External cable runs | Page 2 | on ElectriciansForums
Discuss External cable runs in the Australia area at ElectriciansForums.net
Tony Way
Cambridgshire
Hi Guys
I seem to do a lot of retrofit external lights to properties where they don't want damaged walls inside. So, only way to do it is to run cables externally. Now as we all know, you're not allowed to run 6242Y outside without protection from UV etc. So obvious options are: to run it in round conduit (but terminations via terminal boxes etc don't look too pretty) use SWA, but very few fittings allow direct termination.
Can you use HITUF / NYY-J (i guess if you could there similar issues to SWA), or is there anything else out there that looks better, speeds installation and eases termintion into domestic style external fittings?
Many thanks
Tony
Reply to External cable runs in the Australia area at ElectriciansForums.net
