Hi,
Just looking for a bit of advice, we live in a semi, and the mains power runs along our neighbours wall (about half way up the house) and then goes into our consumer unit which is in the kitchen.
We have just begun building a lean to extension, which effectively means that the mains power is running in an internal wall, with no external fuse etc. The electrician has fitted a metal casing over the mains power, but my question is whether this is the correct thing to do. He says he will give us all the necessary certificates and is fully accreditted, but we are not sure it seems right.
Thank you in advance,
David
David
