extra socket | on ElectriciansForums
Discuss extra socket in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
SRFC
hi all.new here.
im irish so im not sure if its different in englang.in london fo a while.
i want to install an extra socket for a tv.i will be tapping into another socket that has already has 2 wires in each termaina.can i hop of that or what do i do.access to the circuit below floorboards is not an optiondo i use a spur?
Ta
In my view, you are allowed one unfused spur from a socket on a ring, so it seems you can just spur off to your extra socket.
but if you add an FCU, fused at 13A, what's the point of adding more sockets, unless they are only used for low power appliances.
Reply to extra socket in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Cheers guys, enjoyed reading all the responses. I'm an apprentice and it was a conversation that came up at work between two electricians...
2 3
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
