Extractor fan to timer type | Page 2 | on ElectriciansForums
Discuss Extractor fan to timer type in the UK Electrical Forum area at ElectriciansForums.net
Edinburgh
Hi
I’m thinking of changing an extractor fan (in a WC) to one with a run on/timer. The current set up doesn’t have an isolator, and wiring runs from the light bulb to the fan, which is sited in the ceiling about 18” away. The fan is vented through a flat roof above.
Now, I realise that i’ll need a permanent live and to fit an isolator switch. I’m thinking of doing this:
- to leave existing wiring as is, and take a live feed from a lighting circuit junction box in the attic;
- to install an isolator switch in the permanent feed run, ie in the attic.
I’d rather not have to channel into walls to run a new 3 core cable.
Surely anyone looking to service the fan will know it only operates when the light is switched on...
Hi mate. The fan will require a 'permanent live' as well as a 'switch live'. Both will need isolation, as well as the 'neutral'.
Have a look at the manual for the fan you are thinking of getting. This should tell you how to wired it.
What fan are you thinking of getting?
An Envirovent SilentT 100.
Now thinking I could run wires from lightbulb (which run direct to CU (in WC) via switch) and a permanent live from lightning circuit in attic to an isolator switch located in ceiling, adjacent to fan.
As @Tony Reidy asked above, "Why do you need to channel into the wall if all the wiring is in the flat roof "??
why not just leave the light on for 20 minutes? otherwise it's not essential as in a bathroom extracting steam, only fart gas. leave for the benefit of next user. :confused: :confused: :confused:
Single wire runs to switch in WC then up wall into flat roof void, then out at light socket. Linked from there to existing (non-timer) fan.
So there is a switch live wire going to the switch from the light?
There should be a 'permanent live', 'switch live' & 'neutral' at the light then. Can you not tap of these?
Does your CU have an RCD?
This seems to be following a familiar pattern.
DIYer asks for advice
Forum says no don't do that it would be wrong and possibly dangerous
DIYer says no it won't
From here it usually goes one of two ways. DIYer sees sense and employs the services of an electrician to protect their own safety and that of their family and property.
Or the forum end up being tarred as elitist scum whose trade is a doddle and we are only withholding information as we are rip off merchants.
I'm on the edge of my seat.
well, it's only 2 wires 3 wires, 4 wires. oh bugger, it's on fire.
Reply to Extractor fan to timer type in the UK Electrical Forum area at ElectriciansForums.net
Which begs the question, where does the second brown wire come from?
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
