Extractor fan to timer type | Page 3 | on ElectriciansForums
Discuss Extractor fan to timer type in the UK Electrical Forum area at ElectriciansForums.net
Edinburgh
Hi
I’m thinking of changing an extractor fan (in a WC) to one with a run on/timer. The current set up doesn’t have an isolator, and wiring runs from the light bulb to the fan, which is sited in the ceiling about 18” away. The fan is vented through a flat roof above.
Now, I realise that i’ll need a permanent live and to fit an isolator switch. I’m thinking of doing this:
- to leave existing wiring as is, and take a live feed from a lighting circuit junction box in the attic;
- to install an isolator switch in the permanent feed run, ie in the attic.
I’d rather not have to channel into walls to run a new 3 core cable.
So there is a switch live wire going to the switch from the light?
There should be a 'permanent live', 'switch live' & 'neutral' at the light then. Can you not tap of these?
Does your CU have an RCD?
Yes, CU is split rcd, with single 2.5mm T&E cable running (embedded) to wall switch (1m away) then (embedded) to roof void. If this was a 3 core wire instead of T&E I wouldn’t be posting on here ie I wouldn’t have a problem!
So I have Switch L and N. I’ll connect these to a fan isolator switch fixed into ceiling. Then run permanent live from lighting junction box in attic to same switch. That way, single switch will isolate for servicing, complying with regs.
This seems to be following a familiar pattern.
DIYer asks for advice
Forum says no don't do that it would be wrong and possibly dangerous
DIYer says no it won't
From here it usually goes one of two ways. DIYer sees sense and employs the services of an electrician to protect their own safety and that of their family and property.
Or the forum end up being tarred as elitist scum whose trade is a doddle and we are only withholding information as we are rip off merchants.
I'm on the edge of my seat.
Naval gaze all you want. Some of us have got work to do.
Forgot to say, cable connected to 6amp circuit breaker in CU.
Oh. I get it now mate.
But then you will have a fan circuit fed from two different breakers.
Hallelujah! The lighting junction box in atTic is on a circuit that’s connected to same breaker in CU! So I won’t be linking different circuits!
If this now complies with all regs, then saves me a hell of a lot of hassle and mess of ripping into walls.
If you had the tech knowledge you’d explain why it might blue to bits. But you don’t so you make crap gags.
can't take a joke? seems you have the sense of humour of a potato.
We got there in the end mate. That's why we have to ask questions, to get the full picture.
Reply to Extractor fan to timer type in the UK Electrical Forum area at ElectriciansForums.net
Which begs the question, where does the second brown wire come from?
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
