Extraneous and bonding etc | on ElectriciansForums
Discuss Extraneous and bonding etc in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
something that cropped up yesterday on my assessment was that I'd done a load of work on a house and new CU etc.
the old boiler had been taken out and a new one fitted but the gas supply had not been put into the new boiler.
the old gas pipe was left where the old boiler was in a different part of the house.
i didn't bond the old pipe as it was about to be removed and a new one put in.
he said why have you not bonded the gas pipe?
i said it was about to be removed.
i said I have done an IR on it to the MET and it suggested it was not extraneous or already bonded somewhere so was not bothered as I felt it to be satisfactory.
he said what do you mean you have done an IR test in it?
so I explained it was less than 0.03M ohms, it was 0.00 as it happens, so it was less that 23,000 ohms. He said that it should be well over 1 meg ohm. I had to agree to disagree, I said yes but I'm proving it's not extraneous....
am am I right or am I being thick?
Re: Extraneous and binding etc
A reading greater than 22k ohms would prove it is not extraneous. Show him GN8 if he thinks you are wrong, it is all explained in there.
Edit...
It is 23k i believe but 1k is deducted for the body resistance.
230V / 23000 Ohms = 0.01A
I can see why you would not bond something that was about to be removed, even thought the regulations would have otherwise (what happens if a fault occurs before it is removed!!:)).
Electrically you are actually conducting a high value resistance test that is most easily done with an IR tester.
You proved that it was an extraneous part because the resistance to the MET was less than 23 kohms and so it would require bonding.
If you measured with a low resistance ohmmeter and got a very low value (hundredths of an ohm) then you could assume it was electrically connected to the installation, but whether with a large enough conductor is another matter.
Overall from what you say I would say it should have been bonded but this would be redundant in a short time and so had been left as it was electrically (perhaps) connected to the MET anyway.
Hi,
i think it should be more than 22k so the 0.00ohm reading is too low
Yes you are right, I'm confusing myself that's the issue.
I did explain to him it was less than 0.05 ohms between them on continuity which to me suggests it's bonded.
the pipe is coming out this week anyway.
Was the test 0.00 as in first post UK or 0.05 as in last post? First post suggests it is connected to MET somewhere but I'm confused with the 0.05 figure, that would be 50,000Ω. I guess you could have done a continuity check just to see if the figure was below 1667Ω then if RCD protected it would be ok.
I think the first is 0.00 Mohms the last is 0.05 ohms.
RCD protection doe not remove the requirement for bonding, bonding is there so that in the case of a fault to earth all accessible conductive parts will be at the same voltage prior to the disconnection occurring.
Sorry I realise what I've said.
it was 0.00Mohms IR between the water and gas so zero M ohms.
IR tester will only go down to 10,000 ohm resolution yes?
anyway when I tested with a low resistance ohmmeter between the same two bits of pipe it was less than 0.05 ohms, which would obviously show as zero on IR as it's less than 0.01M ohms ok.
Ok, so can you not say there's clearly continuity between the two pipes yes? Sufficiently to say they are well connected somehow ?
am I just being a total spanner here?
You're quite right Richard. UK clearly states 0.05ohms on a continuity check. Also quite right about the bonding.. I was getting confused with supplementary bonding. It's too late for me!
I would have thought so! Hopefully Richard will tell us :smiley2:
Reply to Extraneous and bonding etc in the UK Electrical Forum area at ElectriciansForums.net
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
Why would the RCD fail … yes it can happen but then it may not. Without it you have no protection on the TT System
4K
