Fault on kitchen ring | Page 3 | on ElectriciansForums
Discuss Fault on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
TheCodboy
Newcastle
Hi all. Had a phone call about a tripping RCD. The customer had narrowed it down to the kitchen ring. When I go there,it was indeed the kitchen ring causing the tripping. Firstly checked the usual,nothing plugged in to any of the sockets. Checked the connections at the sockets,these were all fine. Checked end to ends,had continuity on L,N & E. Carried out IR between LN & E at 250v,very low reading,virtually zero. Also tested L-E N-E & L-N. All very low. Now,the cables in the kitchen are red/black and the cables at the board are Brown/Blue. There no sign of any crimps etc at the board (which by the way is a total mess). So I’m thinking hidden joints/jb could be the source of the problem?? Any pointers would be appreciated!
Not sure if this question has been asked before? is the tripping a new occurrence, when did it start, has the customer had any DIY done recently, or did the tripping start immediately after the Kitchen was fitted? sorry for all the questions, didn't mean to interrogate you.
Apparently there has been a neutral fault on this circuit for years. The board was changed about 5 years ago and it was noted. The tripping fault has just started. The kitchen has been in for donkeys years. There’s been no works carried out at the property.[/QUOTE]
But you aren't 100% sure there isn't another connection(s) you are not aware of ...................
Well there certainly one joint at least,as the colours are new at the board and old at the sockets. The wiring is such a mess inside the board,it’s difficult to actually see in which direction the ring goes off. There is trunking with cables coming out of the db in all directions. It’s a total mess. For the sake of running about 10-15 meters of new cable and putting up some new trunking,customer gets their kitchen sockets back. By the time I’ve actually found the fault I probably could have finished putting in e new stuff!
Have you actually found which of the four legs of cable in the ring has the fault on it as reading the posts Gavin (post 8) suggested this as it is not clear to me? Is there another ring in the kitchen as three sockets don't seem a lot.
According to the board there is one circuit for kitchen sockets. The customer has shown me the sockets that they are aware of. I’ve asked about fcu’s etc and they reckon none. I’ve had a look in cupboards etc and I can’t see anything else.
I wouldn't trust that for a start ........... nor the client ....
Reply to Fault on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
Very technical :D
