Faulty Extension Light Circuit | on ElectriciansForums
Discuss Faulty Extension Light Circuit in the The Welcome Forum area at ElectriciansForums.net
Stuart Lane
North East
I had an extension fitted and a single circuit added for the light. However, the light will only operate from the MCB and not the switch. As soon as I introduce the switch into the circuit and operate it from there it trips the MCB and will not stay on. Any thoughts on what might be causing this?
problem would appear to be in the switch or in back of it. surgical removal is an option.electricians are cheaper than surgeons.
Sounds like someone may have dropped a three core down, one core being the neutral but they have connected it to a two way switch, maybe?
It was done by an electrician. I thought it might be the switch and then the light fitting / chandelier. I have tried different light fittings and problem remains. Wiring to light contains 2 Live, 2 Neutral and 2 Earth wires but I guess this is normal.
Warranty - No but I can live with the problem as there are other lights close enough.
2 Way switching shorting line to neutral - explain!
A two way switch will have three terminals, a common, L1 and L2. The common will switch across to either L1 or L2 depending on its position. It is possible a neutral has ended up in L1 or L2 causing a short when you switch it.
So have you fitted a new light?
Did you just join all the browns, blues and green/yellow together?
Reply to Faulty Extension Light Circuit in the The Welcome Forum area at ElectriciansForums.net
I did consider this but ended up going with this one. I wired it inline with the lives and works great.
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
