Yes you need to know the fuse sizes in the switch disconnector for the busbar because if they are 100A this is all unnecessary. If they are 200A then the 125A, 60947-3 switch and the supply conductors need circuit protection, I would guess a 100A 60947-2 main switch at the board would break the bank. Your only option is to use that switch although I am confused by its part no but it looks like the solid links could be replaced with fuses. Shame he opted for that cheap nasty option. You need to go back to square one and confirm the fuses protecting the busbar and remember a 200A switch doesn't necessarily mean 200A fuses.
