M
MikeGT729
OK, like I said, I'll give BCO a ring Monday and double check.
I think you may be forgetting the extra visits when they have to come back after not signing it off. As you say it shouldn't be an issue as it is only two circuits. That rather flies in the face of the information you have been given if you read carefully. You have been told that it is more than two circuits there are other background factors which are too complex to lay out here. For instance do you have a TN-C-S system or a TNS or possibly (rarely) a TT? Are you aware of the implications of exporting PME to other locations? Can you calculate the volt drop for the run? As stated there is more to it the a "couple of circuits" Now... I am not decrying the DIY attempt and personally I am all for you doing this and applaud your sense of adventure for want of a better word. If I were to do the work for you I would have to check with ESF whether your tumble dryer is subject to recall, have you done that? Tumble dryers have a terrible safety record and quite often burn out cabling. Anyway to answer your question, usually SWA is used to supply outbuildings. Terminating SWA is a skill you would have to master to install it. It would need to be buried circa 18 inches underground and properly marked and the correct gradient of stone laid around it. You could use 2.5mm² or 4 mm ² on a 32a MCB. You have not asked about RCD which is rather worrying as it may indicate you are starting from a point of knowledge which is inadequate. Where are you going to use the conduit just in the utility room? because outside you need to use the right colour. Now, again I am all for you doing this, but this is what it involves. Quite apart from BC signing it off all these points will have to be addressed and of course you are the person who will rely on the safety of the design and of course your family. Now...do you want to call an electrician? or are you going to brave it?
Well yes and no. Yes it is, and no as it is standard fare for an electrician. As you say there is no distance and yes it does sound very straightforward. And once again I am all for you going for it. Please don't be discouraged by the nature of what I have introduced. Just trying to let you know that it may not be that complex but equally is is not quite as simple as one could easily assume. What I have talked about is standard consideration in designing a circuit and as we do it almost everyday it is one of those things that is easy, once you know how.Is it really this complex?
You have no discrimination between rcds.
So this Sparky is a council Sparky? is he doing this privately, or on behalf of the council?It's £360 Inc VAT. And this isn't BCO, this is the council's own sparky
I rang BCO and asked whether I could do the install myself, they knew I wasn't qualified, and they said yes, but I would have to have the electrician who works for the council come out and certify, which costs £360, which seemed fine given the few prices I'd had for other jobs.
and i used to think guys from oxfordshire had trouble stringing a few words into a sentence, let alone 4 paragraphs.![]()
