few questions re rewires | on ElectriciansForums
Discuss few questions re rewires in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
Earth
Hi
Just got a few questions I have never been told a straight answer to, but just peoples opinions/ prefs..
For rewires do you have to use capping over your cables or is clipping and just plastering over on top perfectly acceptable if the cable is protected by a 30ma rcd?
Next question:
for socket points under worktops in kitchens, do you HAVE to have a spur above the work top to isolate? or is this just good practice? what if the worktop has a sink in it, not really much room to have a spur above the worktop, without being to close to the sink.
cheers for your time guys
Doesnt matter if it's protected by an RCD or not, capping is there to protect the cable from the plasterers tools. You dont need to use it, it doesnt provide mechanical protection for the cable. Some people use it, some dont.
Well if theres a sink above you could use a bank of switches sited together as is usually done these days.
But is there a reg that says you have to have any kind of switch above?
It's not fixed equipment and isolation is readily accessible by turning off the mcb in the board in the kitchen...
Don't forget that the regs are a minimum standard to work to. Not the only standard to work to. A good spark asks the customer which solution suits them best for ease of use.
Hi tel, thats another reason why i was told to use cappin incase of future rewire. Theres no chance of pulling cables back through cappin, well proberly 1 in 50 chance. So just them U clips. Ill give that a bash in the future. Thanks Tel
Reply to few questions re rewires in the UK Electrical Forum area at ElectriciansForums.net
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
