Hi everyone,
After completing college i've finally been given an opportunity to work as a electrical labourer/mate for a firm on a large site in London.Really happy for a chance but abit nervous as ive not really worked on any big sites..think the works gonna be helping with alot of uni-strut and tray
Anyone got any tips or advice?? as i want to try an make an impression and gain as much experience as i can.. is it a case of turn up, head down and crack on..
Cheers for any advice
Hello
hows it going Mark 1985...
here's what you might want to get to start you off if you can......
A Half round file
Flat file
Hacksaw
a few 12mm Masonry Drill bits (not ones that are too short, 8 inch ones or something...Bosch are good)
a pack of cheap 6mm metal drill bits (HSS) from screwfix or somewhere..
A Bahco Arbour bit(that's the middle of a holesaw for the drill)
a few 25mm Bahco holesaws and a few 20mm Bahco holesaws, the reason I say Bahco is that they are really good and a lot of the other ones are (A) rubbish and (B) just as expensive......don't get too many this is just to give you a start until they give you the usual cheap ones that break after 20 minutes....when they do break(the company supplied cheapo ones) don't let it bother you as they won't care about that...
A few hacksaw blades
a cheap measuring tape
a cheap steel ruler (maplins are good for this) for marking lines...
A cheap pair of pipe grips (glandies) like the Rolson ones from Maplins
a handfull of cheap marker pens for marking metal (Poundland shops are good for this)
a pair of work Gloves (until they give you gloves)
a pair of safety glasses from ebay or Screwfix (Uvex and Bolle Branded ones are very very good) - you really need these, especially for metal munching...
a packet of ear plugs (to start you off) you can get these cheap from Screwfix or out of any small tool shops.....don't buy them in a builders merchant shop or from a DIY superstore or they will rip you off...
a cheap shifting spanner (small size)
a reasonable hammer, such as a Stanley one, you maybe don't want to spend 50pounds on an estwing one just yet as it would probably get pinched...a stanley will be about 10-15 pounds...
one pair of cheap chunky pliers (a tenner or under is fine)
a small magnetic spirit level(pocket level) such as a Stabila, make sure its one with a magnet on it, shouldn't cost more than about 15pounds...
a Drill chuck key, they are ok priced at screwfix...
one tin of WD40 for threading and cleaning conduit ends...
a good pair of sidecutters (wire cutting pliers) such as Knipex ones....these are about 25 pounds but they are good and last a long time...
a tool belt to put it all in....
mark all of your tools as you think best with paint or permanent marker pen to make them easily identifiable...
if you can get very cheap paintbrushes nearby or from a screwfix/screwfix website (the 60p ones) then 1 or 2 of these would be handy to have in your toolkit for painting on the Galvi Zinc paint on cut UniStrut etc...
in addition to your tools, buy an assortment of plasters, a small pack of savlon wipes, a couple of individually sealed Bandages and 1 or 2 small bottles of eye wash for your piece bag (lunch bag) and there are instant ice packs available in some chemists and on ebay or through an online first aid company such as Bostock Healthcare, these are good to keep around for bumped knees that can happen, they have granules inside and you squeeze the bag until the seal inside bursts and mixes them, the ice pack freezes up in seconds....very handy and about a pound each...
if you need a hand with tools let me know and I will see what I can do, have helped out new starts on here before...
any questions just ask...
