fire alarm help | on ElectriciansForums
Discuss fire alarm help in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi,
Does anyone know of a good replacement for the following smoke alarms (pic attached) can't seem to find a like for like.
thanks.
Apollo S65 will work fine, just make sure you get the red cables the correct way round, L1in / L1out....connect both black cables to L2, the measure voltage across L2 to each red wire, the red cable showing 27v dc connects to L1in.
Thanks. I tried to replace it with this cooper cdb300 but it kept showing fault on the panel? any idea why this would be i tried various wiring combinations but kept showing fault.
The menvier range use negative head removal detection, hence the diode is on the negative side (between 1 & 2) so not really suited to normal conventional panels
Reply to fire alarm help in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Have you checked the RJ 45 type lead that connects the pcb to the power supply in behind is properly connected? What voltages do you get at the...
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
