Fire panel wiring | Page 2 | on ElectriciansForums
Discuss Fire panel wiring in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
That’s what I need. Something that is monkey resistant…lol
Splendid! That settles that then…lol
One never knows whether some engineers are on some sort of windup. They make us do all sorts of things at work. Cables have to be P-clipped or if on catenary’s & tray work have metal tie wraps every meter. If the down drops are in YT trunking the cables have to be buckle clipped inside the trunking. I swear they make all this stuff up.
thats normal kam,personally i prefer every job to be done in galv,its more expensive but you get a proper job.
Reply to Fire panel wiring in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Have you checked the RJ 45 type lead that connects the pcb to the power supply in behind is properly connected? What voltages do you get at the...
Hi. I have a wired Optima alarm. Due to wiring access issues, I need to add a wireless door sensor. Sometime back, I recall seeing a product that...
