Fire rated downlights | on ElectriciansForums
Discuss Fire rated downlights in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
My customer, who has a lot of downlights (12v )throughout the house would like them all changing to mains led. I pulled a couple down to check the connection - JB in place so I could cost accordingly. I have noticed that all fittings including ones with habitable room above are not fire rated.
Am I obliged to change to fire rated? In essence I'm removing transformer and changing lamp holder.
I would always fit fire rated, even when I'm not obliged to. I usually find little or no difference in price between fire rated and non fire rated fittings, so struggle to find justification to use a lesser protected fitting.
I would normally if im fitting from scratch ,but I dont want to incorrectly inform customer that she has to replace whole fitting. If I can use existing fitting and just change lamp holder to gu10 then its cheaper for her.
just replace the lamp holders and lamps. removing the transformers as you go. ssimplesss.
Reply to Fire rated downlights in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
The core tech was never Google. The core technology was Nest, and it’s sound. They got bought up by Google looking for a way in to the home tech...
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
