First electric shock | Page 2 | on ElectriciansForums
Discuss First electric shock in the UK Electrical Forum area at ElectriciansForums.net
everywhere
Some of the regulars will know I'm in training...slightly confused...all day today I've been sleeving the cpc because none at all had any on and putting connector blocks in choc blocks..15mins before leaving I have my head above the ceiling...power on since where we are working are open and they don't want a third of the store in darkness from killing the mcb.
Had the connector block between finger and thumb..carefully putting it the choc block when I heard it cracking..was tightening the screws when I got a belt.
So I'm thinking could it arc...I didn't see anything...just felt it.....or Is it more likely I just had a brain fart and my thumb touched some exposed conductor?
I
Least I know the rcd kicks in fast
No need to be "babbing it", that's what safe isolation is for, to give you confidence you are working on a de-energised circuit.
Take this shock as a learning experience. If you don't learn from it then you probably deserve another shock. Get your AVI on anything you disconnect. Even if a circuit is isolated, you never know what you are getting hold of, especially above a suspended ceiling.
That's fine..if I had it my way it would of been dead..but I was working on that one circuit all day today and they didn't want to be without light for that long
Certainly wasn't me that wanted to work live..of course I always kill every circuit I can before work..just today they didn't want lights off..gaffer said taking conductors out..kill circuit..but just putting a choc block on it can stay on
Christ "DON'T WORK FREAKING LIVE MATE" bloody hell what's this trade coming to?
Yes ! unless you like putting your life on the line. Your Boss is breaking the EAWR and health and safety laws by asking you to work live when it is not necessary to do so.
See this Is why I came in here..now I have other ppls opinions on it..thanks
google safe isolation procedures, print it out and pin on your boss's forehead, ohh and read it yourself before you go to work tomoz:nuke:
Am I supposed to refuse to work then when the main guy says hold the connector block....genuine question
Yes! When there is a means of isolation then it should be used unless there are incredibly good reason not to. The store owner not wanting the place dark is not a good reason.
How would he/she/the company have reacted if you had been blown off whatever you were standing on and injured yourself or been killed? With the HSE crawling all over them and your employer that excuse would not wash.
Get your gaffer to rig some temporary lighting so that you get to go home at the end of the day, not to a hospital or mortuary. You're a trainee, you probably don't want to question your employer or rock the boat by going against what those above you in the food chain say but for your own sake mate tell this clown that what he's asking you to do is dangerous
You are making it like I went into work today and thought fuk it I'll work live
That site didn't want the lights out
Boss said if taking conductors out .kill it
But just putting a connector block in a choc block is fine
My years experience .over his 12 or so...I usually listen to him
Thank you very much trev..I don't want to lose this job or opportunity and I do believe stuff he says...why would I question him when I have so much less experience
I only wanted help and advice..not a roasting......I got that earlier
He is just cutting corners to make more money, I have about 40 years experience matey and I wouldn't tell any trainee/apprentice to work live, just suppose you were killed? I bet he wouldn't "I told to make sure he isolated the supply" now would he? but he would be deep in the brown stuff if you were injured in any way, yes most Sparks get a belt, usually through stupidity, take it from me you have been lucky, check out the google thing I sent you and have a butchers at some of the electrical accidents on youtube,
Any roasting you get here will be done from concern mate. I don't think anyone is having a go at you as such.
As far as I'm concerned you've been asked to do something which a trainee at your level should never ever be asked to do.
I've got a first year apprentice with me at the moment and I wouldn't dream of asking him to work live.
He's a clown not you Trev the muppet telling the OP to hold the connector it's OK, Jesus
One of the most dangerous places to get a belt is on steps or ladder , also you say an RCD was in place , well if it did operate you were lucky , if you got a belt between L & N and you're on insulated steps , the RCD would probably have never operated , the message is clear son ,DONT work live and test first before you start work ..
If you don't want to rock the boat the HSE have a 24 hour line you can ring and you can talk to someone about your concerns, if they think they're valid then they'll visit the site and if necessary someone will get their arse handed to them on a silver plate.
I did it about 10 years ago when there was asbestos being stripped on a site I was working on, I thought it was a bit dodgy so rang them, they "happened to be passing" the following day and "noticed the stripping" going on and "decided to inspect the methods, risk assessments etc.
I think we have established that you and your supervisor were in the wrong to be working on a live circuit.
If the owner of the shop does not want the lights off for you to work then the sensible solution is to arrange to do the job outside of trading hours, a couple of overnighters is a lot better than putting your life on the line!
Now the question is what are you going to do next? Your life has been placed at risk by your employer, you need to put this in the companies accident book and report this dangerous incident to the HSE.
Reply to First electric shock in the UK Electrical Forum area at ElectriciansForums.net
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
