The pump is switched from the boiler itself and feeds the circulation pump on the Unvented Cylinder. At least it does on an Ideal Boiler, principles should be the same.
Do you mean feeds the circulation pump on the underfloor heating
No the circ pump for the other Rad circuit, yours is a bit of an S Plan+
I agree its a bit of an S Plan Plus, I understand that from the CH aspect the room stat calls for more heat which in turn opens the CH Motorised Valve which starts the boiler and then the pump pumps it round the radiators.
But
In the underfloor heating there is a Manifold pump as well.
