FIRST HOME - Help with new Consumer Unit | Page 6 | on ElectriciansForums
Discuss FIRST HOME - Help with new Consumer Unit in the UK Electrical Forum area at ElectriciansForums.net
DaniQ
Perth
My partner and I bought our first house a week ago. We don't have much DIY experience but we are determined to learn and do as much work as we can to save cost.
The house is a 3bed an ex-council house built in 1959 and needs a complete refurbishment.
The existing CU is not too old (pvc wires) but we have to add sockets, electric shower...and we prefer to get it upgraded. Please see photos.
I have had an electrician having a look a few hours ago. He said he can move the CU 180 degrees facing the hall with the length of the existing cables. He quoted me ÂŁ250 for moving the CU, including new CU.
He said he could install the following CU:
http://www.screwfix.com/p/british-g...dual-rcd-consumer-unit/2920g?_requestid=39295
If I replace it I would like to get a good quality one with space for more modules and individual ring per floor for the lights and sockets, 2 sockets outside, an electric shower, induction cooker, oven...
I am thinking something Like:
RCD 1
32A Upstairs Ring Main
6A Upstairs lights
6A Smoke Detector
16A????? Immersion heater - in case the gas boiler fails
RCD 2
32A Kitchen Ring Main
32A Downstairs Ring Main
6A Downstairs Lights
45A Cooker
Do you think I could reuse the RCBOs from my current CU for the new one :
RCBO 1
Electric Shower (9-10kw)
RCBO 2
Outside sockets or kitchen sockets
My questions are:
1. Could you recommend a better Consumer Unit?
2. Would it be to much work and too expensive to split the existing ring socket and lights per floor? Or should just leave as it is?
3. What do you think about using the RCBO for shower and outside or kitchen socket?
4. Could you please arrange the two RCDs in a better way?
5. Do you think the MCD specs are OK (amps)?
6. What do you think about this job for ÂŁ250?
Thank you very much. We are quite stressed wih the refurbishment and your help would be much appreciated.
[ElectriciansForums.net] FIRST HOME - Help with new Consumer Unit
Do what you want, I've only been doing Electrics for over 20 years, done an apprenticeship etc. What do I know, but don't come posting on here when you can't get it signed off because you have used a plastic board and not a metal clad one as per the regs but what the hell, just do what you want.
:joycat::joycat::joycat:Calm down mate, Ive been doing it a fair bit longer than you and know what i,m talking about.
The op is fishing on various sites for info........does the mystery polish electrician exist? I doubt it. I'm just debating whether the existing ccu can be re used.
No starbreaker are not obsolete.
i stand corrected. just was looking at a couple of RCDs i have in stock from a strip-out. 2 porongs, but the N is separate so those 2 prongs must both be L's. if that makes sense.
Sorry I thought you where the OP, my apologies, he just needs to sort it out with his electrician and stop posting on every forum under the Sun, again sorry, I've had a carp day with a carp CPN board that shouldn't even be allowed to be sold.
No worries mate, it can get confusing who says what!
Can't stand those cheap boards, CPN, BG etc i think they are the reason Amendment three was introduced! Is CPN Citys own brand?
in ref to post #75 yes but the 1 module ones fit. the bus bar is continuous in these boars, they had plastic inserts in the split load ones but this is a straight bar so nothing else in the board needs changing. lets face it its not going to get a certificate on anyway that's even if this polish electrician exists, I would much sooner a DIYer use that crabtree board over a new BG one as he's got a third more connections to potentially leave loose with his neon screwdriver!
Very confusing sometimes the client supplied the board from yesss electrical I wasn't impressed to say the least, I don't know how some boards can be sold.
I don't understand it its like putting cheap tyres on your car though, people do it despite them being the main thing holding you on the road!
What's more daft is MK boards are so so cheap even at screwfix etc yet people still buy these BG boards etc
Agree, MK and Wylex both very cheap at our wholesaler at the moment.
Reply to FIRST HOME - Help with new Consumer Unit in the UK Electrical Forum area at ElectriciansForums.net
