Fitting smokes in dual rcd board? | Page 2 | on ElectriciansForums
Discuss Fitting smokes in dual rcd board? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I think you can still put the smokes on a lighting circuit, providing it is a seperately electrically protective circuit i.e. a seperate RCBO covering a lighting circuit and smoke alarms?
Reply to Fitting smokes in dual rcd board? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
