sparkie_Al
Hi, I have done the 2377-22, but as an old git I still feel that some fixed appliances do not come under the umbrella of PAT testing. Most test machines do their calculations etc based around the 13amp cartridge fuse, but cookers are generally 30amp, or 45amp, so to me they surely shouldnt come under PAT testing.? Using MFT for earth bond and IR should suffice anyway, as I know that every appliance connected to the fixed wiring is supposed to be tested. The Shower however...doesnot, nor it would seem would Nightstorage heaters, so there is a split already.
When the Pat tester was first let loose on the fixed wiring, I remember loads of boiler circuit boards having to be replaced.
I am sure this subject has come up before, but searching "fixed appliance" did not bring me anything up, so sorry if I am repeating an old theme.
