Fixing a miss-drilled beam | Page 2 | on ElectriciansForums
Discuss Fixing a miss-drilled beam in the UK Electrical Forum area at ElectriciansForums.net
CRAWLEY
I'm building a flat-roof extension on my house and I've got a guy helping me. Sadly he's miss-drilled the holes in the joists right next to the wall (within 70 mm) instead of .25 - .4 of the beam length. Actually, it looks very nice, but not in line with BRs. If we move the wiring (and pipes actually) to be in line with BR, how should I patch the holes? Can I put a steel plate over them? What to do.
Steve.
I think they have been over-sized
Check your span and centre to centre spacing against this table...
(taken from "Building Control Guidance Note, Subject: CEILINGS AND FLAT ROOFS, Timber sizes and construction details")
[ElectriciansForums.net] Fixing a miss-drilled beam
...to check if they actually are oversized first. (i'm guessing not, now, unfortunately for you.)
Knock up some wood dowels and hammer into holes with some PU wood adhesive let dry and trim off ends, then as sparky chick said glue and screw 18mm ply either side of the joist 500-600mm past the holes if possible,should be more than adequate for a flat roof
You're right, I've just checked. It's on the edge.
But I'm happy with the solutions suggested here.
Depending on the size and placement of holes,a clued up BC inspector,may well not require you to do anything.
Those advocating the bolting of plates,need to know more about the dynamics,of how a beam functions. You may make things worse,by drilling yet more holes,for bolts...
Get the plasterboard up quick, before the BI comes round :)
That's by far the most sensible advice yet given. It's just a few bloody holes for goodness sake. How the hell can a flat roof be properly load bearing, is someone going to put an outdoor Jacuzzi on it? You could have had the job done by now.....
If you are going to do job properly the do it properly, no bodges allowed.
Maybe your customers should check on the amount of expanding foam and grip fill that you use ;o))))))
Reply to Fixing a miss-drilled beam in the UK Electrical Forum area at ElectriciansForums.net
