Was changing a storage heater today, I’ve used 6 spring toggles to fix it to the wall. No straps behind the wall at all, is this safe? Seemed solid when I was giving it a pull. Didn’t have any wood for fixing a pad
Discuss Fixing storage heater in the UK Electrical Forum area at ElectriciansForums.net
Was just thinking that, there is quite a lot of that flimsy rubbish around here.This sounds like a paramount board wall, basically two plasterboards with an egg box type separator that puts the boards about 30mm apart
Could well be thatThis sounds like a paramount board wall, basically two plasterboards with an egg box type separator that puts the boards about 30mm apart
You must have a better class of customer.Anyone would think the storage heaters are being fixed to the ceiling.... ?
With the feet fixed proper the only problem might be some daft burger sitting on them and forcing from the wall. ?
Reply to Fixing storage heater in the UK Electrical Forum area at ElectriciansForums.net
