Fixing to a plasterboard wall? | Page 2 | on ElectriciansForums
Discuss Fixing to a plasterboard wall? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have been asked to fit the following
[ElectriciansForums.net] Fixing to a plasterboard wall?
A Glimpse Mirror and shaver socket.
Overall dimensions: 50cm H x 39cm D and weight is 6.2 kg's.
I think it should be ok on a plasterboard wall but just wanted some opinions (with regards the weight)? I wont be able to locate it on any joists because of where she wants it.
Cheers all...
Thanks all, thats reassured me :D
Thanks Guitarist,
The lady was kind enough to give me the mirror so I could have a bit of a play. I really like using the twirlies (spitt) so will probably use those, but its good to hear all the responses saying it will be fine. I thought it would be, but the backup is reassuring.
Aye, I can just about remember the times when i was working and some of the lady customers would let me have a bit of a play. Happy days they were, but now alas, just a distant memory. :(
Twirlies are great, i use em loads. Not relevent to this OP but the only thing I would say about them is not to use them on bathroom cabinets etc. With repeated opening and closing they will eventually work loose.
I always mark the width and the height then I look for a batten and if I find one then it 2 good fixing then a couple on the plasterboard did this for a guy who seen his mate had one and he thought I was being a bit fussy then 3 months later his mate was pulled out of his bed at 4 in the morning with the cabinet smashing the sink off the wall that funny enough was fixed to the plasterboard but the was the least of his problem it was what to do with all this water shooting all over the bathroom lol
I normally call them the sharp annoying things that bite you at the bottom of your tool bag when you've accidentally spilled the box!
They certainly will, use toggles or cut hole in p/board just below fixing points, slide in a bit of 2x1, ensure that 2x1 is in position to recieve cabinet screws and secure with a couple of drywall screws. offer up cabinet and gently but firmly screw in cabinet screws thru plasterboard and into 2x1. yes you will have a hole in p/board, but you won't see it. keep cut out p/board in case you put cabinet in wrong place:smiley2:
Reply to Fixing to a plasterboard wall? in the UK Electrical Forum area at ElectriciansForums.net
