Fixing to a plasterboard wall? | Page 3 | on ElectriciansForums
Discuss Fixing to a plasterboard wall? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have been asked to fit the following
[ElectriciansForums.net] Fixing to a plasterboard wall?
A Glimpse Mirror and shaver socket.
Overall dimensions: 50cm H x 39cm D and weight is 6.2 kg's.
I think it should be ok on a plasterboard wall but just wanted some opinions (with regards the weight)? I wont be able to locate it on any joists because of where she wants it.
Cheers all...
I can't think of a better plasterboard fixing than the spring toggles (especially if what your fitting has any weight to it) that have been around now for donkey's years. I certainly would never trust these Twirlies, ...over tighten just a little and your fixings gone!!
Agreed, but they do have some major drawbacks in fitting - having to fix them 'complete' through the material being fixed, needing about five hands if it's something big, having to tighten them at first using a pull and turn, one-time use, and if say on a 4-point fix you need to take just one out then you loose all four! Plus, you normally end up needing a load of penny washers at the load end as the heads are too small on the M4/M5 threads.
Like in many things, there is a knack to using toggle fixings!! lol!! The penny washers also act to spread the load, (you only need one per toggle, two maybe if very thin). I've hung pretty sizable 6 fixing panels on double boarded partition walls by myself in yesteryears, can't remember needing or wishing for 5 hands. lol!! Just fairly accurate measurements and the correct drill size to allow the toggle to just pass through. As i remember, i just pulled on the penny washers while screwing, to take up the initial length of bolt thread!! Oh, and a one time use is all you should need!! ...lol!!
I always thought the collapsible bolts were called Spits because they were a pin in the bum when used with the little spanner that came with them.
I then discovered Spit was a brand name. After that I discovered there was a fixing tool. Use them all the time now. Well, apart from fitting socket and switch front plates!!
I can only remember Toggle fixings coming with a slotted head for flat standard screwdrivers!! But then i've never heard of the brand name of ''Spits''!! lol!!
Theres a Curver box available in Screwfix full of RAWL brand drywall fixings, think they are still on the ÂŁ3 special offer that they do now and then, got one here, 8 compartments, box is about 25cm x 40cm....
Reply to Fixing to a plasterboard wall? in the UK Electrical Forum area at ElectriciansForums.net
