Flat bits, what do you recommend? | on ElectriciansForums
Discuss Flat bits, what do you recommend? in the Electrical Tools and Products area at ElectriciansForums.net
polo1
Glasgow
I’ve tended to use Irwin flat bits in the past, but I’m finding they are loosing their cutting edge really quickly.
Anyone recommend an alternative which lasts more than a couple of holes in softwood?
I'll second the Bosch @Leesparkykent is recommending with the caveat, I've only got one. I've not had to replace any others yet as they don't get used that much, but they'll be getting replaced with the Bosch.
It seems to cut so much better than the others I have. I can't remember what they are but I've not scrimped and gone cheap on any of my gear.
I use these bits only .
[ElectriciansForums.net] Flat bits, what do you recommend?
Cheers SC. I realise the Irwin bits are not that costly, but for something that “appears” to be well made, I’m just finding that that they are blunt in the blink of an eye!
Happy to spend more for something more durable. I too believe to buy the best quality tools you can afford, but for what is a disposable purchase, are you better buying cheap & often?????
As above I got myself some Irwin Stubby Auger bits and can't fault them, find they go through joists very well and also as they are not so long it means you have a bit more room to get bigger drills in the space you are working. paid around ÂŁ20 for a set of 6 back last year. Not a fan of flat bits anymore, and doubt id go back having used the auger bits.
by cheap ,pay twice, they say stated use in them since they first came out .
Reply to Flat bits, what do you recommend? in the Electrical Tools and Products area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
