Flat roof electric velux > 'no contact' message on pad | on ElectriciansForums
Discuss Flat roof electric velux > 'no contact' message on pad in the UK Electrical Forum area at ElectriciansForums.net
London
Hello,
I've got an issue with my electric flat roof skylight velux: the pad reads 'no contact' with the flat roof velux. Please see attached picture. Have you come across this issue before? The plug is switched on.
[ElectriciansForums.net] Flat roof electric velux > 'no contact' message on pad
Thanks very much everyone!
  • [ElectriciansForums.net] Flat roof electric velux > 'no contact' message on pad
Reply to Flat roof electric velux > 'no contact' message on pad in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
Hi, Has anyone come across DIY balcony solar panels? These are solar panel kits you can buy that plug into a regular electrical wall outlet...
  • Yoult1976
  • Ireland
  • 0
  • 160
