Flat twin cable with sheathed CPC. | Page 2 | on ElectriciansForums
Discuss Flat twin cable with sheathed CPC. in the Electrical Tools and Products area at ElectriciansForums.net
I was an apprentice in 76 and cant remember what colour the sleaving was, I think it was green/yellow but always referred to as green sleaving.
Yes it had to be insulating as opposed to conductive but it wasn't there as an insulator.
Here is the regulation:
D29 (ii)
Where the sheath of earth-continuity conductors complying with reg D28(i) is removed adjacent to joints and terminations, earth continuity conductors of CSA up to and including 6mm2 shall be protected by insulating sleeving complying with bs2848.
D28(i) refers to CPCs within cables (not flex).
Make of it what you will, but to me its main purpose is as an insulator.
6193B (I'm assuming you need LSF) has been available for years. While it doesn't meet any British Standard, I can think of nothing that prohibits its use.
Other cable types are also available with insulated CPC and are widely used in 3ph installations. I do occasionally come across T&E in 3ph boards, but it's a very rare occurrence.
What are the alternatives with the sheathed earth?
Reply to Flat twin cable with sheathed CPC. in the Electrical Tools and Products area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
