The kopex doesn't look good but its an aesthetic problem. Judging from videos his work is to a good standard. Everyone is quick to point out faults from behind their keyboard, when the majority of us don't put our work on display for others to pick faults in, myself included. I think we can give him a bit of slack with this one.
to be fair to Nick his work is normally class , I feel he was almost trying to be too ‘neat’ trying to put the twin & earth through kopex , it really was over kill and in the end looked a bit ‘naff’...
had he simply wacked up some 50x50 trunking or even just clipped the cables to the bottom of the joists it would have done the same job at half the expense
DD, yeah clipping cable today seems out of bounds, with the new generation of sparks, and I don't know why.
Agree and I really don’t understand why , neatly dressed & clipped cables are perfectly acceptable...unless at risk of getting bashed.
nick could have clipped the cables underside of the ceiling joists and it would have been perfectly acceptable imo
I like the idea of containment where cables are visible, but feel that it should allow ready access and (if used) needs be more aesthetically pleasing than no containment.
As previously stated; no one is at any risk from his use of kopex and, having read a few comments on the video, it seems the customer was very happy. It does seem to be a case of trying to hard and in the process made a less than ideal choice.
Still not liking the idea of that foam though :p
Plastic clips, and the passing of buckle clips, has in my opinion caused the trade to turn into a bash it in and ignore the ascetics of installation work, there are folk out there that ignore the cable management side of things, as long as the CU internals looks like it grew there, jobs a good un, can be seen by the number of Electrician showing pics of a finished CU, but not how the cables get there, the skill of clipping twin and Earth, has sadly disappeared, the same can be said for all surface mounted cables.
[automerge]1597495960[/automerge]
Probably the reason the customer was happy, stems from the fact the the customer is ignorant of the methods available to skilled Electricians, as long as it works OK they will be pleased.
Interesting posts, in Europe where flexible conduit is used extensively there is legislation that does not allow filling a conduit to over 2/3rds of its cross section, this equates to a maximum of 3 x 2.5 singles in a 20mm flexible, I don't know the c/c of T&E, but think it would probably come to more than a 2/3rds of the internal area of a 20mm flexible at 52mm2, anyone know the official cross sectional area of T&E?
Plastic clips, and the passing of buckle clips, has in my opinion caused the trade to turn into a bash it in and ignore the ascetics of installation work...
The old house I grew up in was wired in the 50s with VIR and buckle clips. None of that wiring was on display, but the installers didn't care that no one would see it - everything was carefully clipped with fastidious neatness and the pride taken in that work was clear to see. Some later additions were also installed with thought and care, but much of the later wiring was thrown in without care for anything other than getting paid and getting out.
containment was designed to house single insulated cable ?
twin and earth was designed with its own incorporated an outer sheath so to be ‘clipped direct’
so why are we bothering to contain twin and earth cable
does it really take that much longer to neatly clip 10 cables rather than struggle to ram it throughplastic conduit
Depends on the type of clip DD, they don't teach proper clipping these days at instant Sparky School, sadly bo longer considered a necessary skill, just pay up and pass the tests.
Might be considered neater. Could take up less space if properly thought out. Allows for future boarding of that garage ceiling.
It's not necessary, but might be something to discuss with a customer when quoting for a job. Some will be happy with clipped cables, but others might prefer paying more to place them out of sight.
[automerge]1597498900[/automerge]
I doubt it's quite so clear cut. Certainly an apprenticeship should provide more opportunities to learn a craft, but plenty of people time served tradespeople don't seem to care much for attention to detail. People will either have the inclination to do things to a decent standard or they wont. The rough electrical work I grew up around was installed long before faster routes were available into the trade.
Neatness and time saving.
T+E was designed to be clipped direct but why should it be?
What about entering or exiting dado trunking with cavity walls, for example?
In this (through garage) situation, with all outgoing cables from a CU, I'd have installed plastic trunking thirty years back.......T+E or not.
It's a matter of looking at the best possible method of rearranging wiring routes in an existing property.... not wiring from scratch, when various means of clipping could well have provided the best method.
We still see methods for improving aesthetics from the 1920's even,......remember capping and casing?
The house I currently live in still has all that old wiring beneath the stairs to where it would have connected the the board at one stage and its like a work of art i dont can't bring myself to remove it
