Yes, quite right to.The question is certainly valid, for someone of very limited experience and knowledge, not for someone about to undergo an assessment for a competent persons scheme.
Discuss flood light cable in the Lighting Forum area at ElectriciansForums.net
Be more positive man! a valid question was asked.
what are you saying, the sheath is porous?
Pretty sure you are right there im sure it has to be classed as notifiable work to be assessed on. Additional circuits or consumer unit changes or work in special locations but I might be wrong.Do you have any other electrical work to show your accessor? not sure this will be accepted on its own. they will want something like a consumer unit change or multiple new circuits added (which will need to be tested prior to them attending) as they will ask you to perform a random set of tests, as well as other things. when is your assessment?
If it's visible and out of any obvious danger, I'd use H07RN-F (Not to be confused with H05RN-F which most suppliers stock but is less resilient, and personally I wouldn't use).You'll probably have to mail order the H07. It's tough stuff. Very rubbery
Are you sure it's H05RNF? That has the same sheath and physical characteristics as H07RNF, it's only the electrical characteristic which is slightly different.
Most wholesalers will stock HO5RRF which is the softer sheathed cable.
Interesting.
I find H07RN-F to be thicker and heavier and more floppy than the harder sheathed thinner H05xx-x stocked by most wholesalers.
I find this http://www.goldwingcable.com/wp-content/uploads/2015/08/H05RR-F-Technical-data1.pdf which reads "This is unsuitable for permanent outdoor use in industrial buildings for non domestic portable tools and for underground laying" versus http://www.goldwingcable.com/wp-content/uploads/2015/08/HO7RN-F-technical-data-sheet1.pdf
The same site You searched for H05 RN-F - Goldwing Cable - http://www.goldwingcable.com/?s=H05+RN-F classifies H05RN-F and H05RR-F both as "light Duty".
Reply to flood light cable in the Lighting Forum area at ElectriciansForums.net
