floor boards | on ElectriciansForums
Discuss floor boards in the Australia area at ElectriciansForums.net
yorkshire
Hi Guys,
Just wondering what method you use for getting up floorboards without causing too much damage ? :smartass:
I tend to use a jigsaw to cut the board, both down the grooves if it has any and across the the board itself if I only want a small section up, going where the nails are to be sure you're on the joist.
circ saw or multitool fein type but just a cheapy one. most houses I have had the fortune of being in after the central heating so they had been up anyway and like Billy said not too well taken up either :D
I Have a cheapo feintool type tool from Aldi and so far it's been great! I will probibly get the bosch equivilent when it dies. Great especially if you need to lift close to walls ect.
Rich
oh and try and lift a board where two floor boards meet, that way you can set your circular saw at the right depth, and you wont cut through anything that may be running across the joist in a shallow notch such as a pipe or some previously installed ring mains, lighting cables and shower feeds, not that i have ever done that of course :blush5:
Whatever you do dont ask the plumbers to do it!!!!!
there are several ways of finding where plumbers have lifted boards.
1. water marks on the carpet.
2. creaks when you walk over.
3. bloody great draught from under floor.
4. 4" nails in boards, impossible to remove without destroying the board/s.
5. notches in joists big enough for a bus, rarely within the prescribed zones.
6. burnt and blackened joists and cables.
7. hot pipes threaded through, or sitting on, cables.
Reply to floor boards in the Australia area at ElectriciansForums.net
Rather than covering the issue, find where the moisture is coming from and address from that end, is the outside ground level above the inside, is...
Which is the Best Tile Adhesive for Floor Tiles? Which Tile Adhesive Did You Use Most During 2010? Please vote on the Poll. All answers can be...
DHTiling
