floor cutting or bust the ceiling ,neatly as posible | Page 2 | on ElectriciansForums
Discuss floor cutting or bust the ceiling ,neatly as posible in the Australia area at ElectriciansForums.net
i=p/u
Northern Ireland
marked out me first row of lights in 2 rooms to finish up today for tomorrow, i can get to above ceiling but the floorboards are the groove ones and im hopping no noggins in, as they nightmare to get back down, then was thinking maybe just cut a 100mm track out with angle grinder on ceiling beside the lights, which do you think will be more boring and lest constructive.. on top of the floor boards there is loads of chairs and tabless.... help
im using 6mm hi tuff just going to run it in back of cu, surface mounted. then for circuits comming out ive studdied the cu and if i cut the knock outs carefull the 20mm conduit wil just sit in there, not the best was i suppose, but it will work. is there a height to install cu, and any tips on stripping high tuff, dont think il struggle but if yoy give me good tip, well happydays.....
Reply to floor cutting or bust the ceiling ,neatly as posible in the Australia area at ElectriciansForums.net
