- Joined
- Aug 11, 2007
- Messages
- 169
- Reaction score
- 52
Hopefully someone here has the necessary experience to explain the issues below.
Metal bashing unit with two TIG welders and a Mig welder. The problem is the breakdown of the switch start fluorescent fittings. I believe the ballasts are breaking down and leaking to earth causing nuisance tripping of main the 300mA RCD. I have swapped two out so far and replaced with high frequency units, but have had to remove two more from circuit to keep the lights on.
I have been reading up and have come across information regarding welders causing odd order harmonics that can damage the fittings, can someone explain the effect and possible methods to reduce or eliminate the problems.
I should like to explain that I was not responsible for any of the electrical installation, it was done by a friend of the owner !
It has already been necessary to remedy some crap work, shorting connections in metal boxes etc.
I look forward to the usual intelligent and knowledgeable reply's...
Many thanks
Many thanks
