Fluke Multi Testers | Page 3 | on ElectriciansForums
Discuss Fluke Multi Testers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I know a lot of sparks who are having problems with fluke meters! Failing to calibrate, zero readings on earth loop tests!
Back to Meggar, never had one problem with Meggar multi meters! :)
My fluke stopped zero-ing on loop test, it just needed new batteries:) cracking tester, had it 5 years now
i think my fluke 1652C is fantastic, used it for 2 years now. the only gripes i have it 1. the fact you have to zero the leads for an earth loop test and 2. the remote probe kept giving different readings so had to bin it.
you shoudn,t have to keep zeroing leads fluke remembers leads mind you could be a good idea still not sure about remote lead i have used one for 5 years and still ok tested skts with lead and plug in results come out same
Never had a problem with my 2nd hand 1652.
Has someone got a Megger franchise perchance??
Originally Posted by robswainelect Cant remember, not got it here?
I'm sure if I'd bought 3 "piles of do do" from the same Mfr. I'd remember the model numbers to avoid the same mistake. Having said that, I'd have probably not gone past "pile of do do" #1.
my thoughts exactly
never had the pleasure of using a fluke. always had megger, except for 1 seaweed which was a pain in the arse.
Reply to Fluke Multi Testers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
I just had a look, and the Klein and the Southwire are both "True RMS" meters, whereas it appears the Fluke is not, as it says "averaging" against...
