Fluke Multi Testers | Page 4 | on ElectriciansForums
Discuss Fluke Multi Testers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
got to agree all us users need to know if certain one,s are causing problems
when i was at college there was one thing i found out about flukes.
there very fussy about batteries, the screen starts disappearing etc when battery starts getting a little low.
so changing battery brings it back to normal
i have a fluke 1651b multifunction tester which at the moment has been fine ,although when the batteries are low it does start to play up last time it wouldnt let me null my leads i changed the battery and it was fine.
most meters have that problem not just fluke
i see.i used kewtech seperate testers (continuity and IR,earthloop,and ze and rcd tester) and didnt have this problem. At least i know its not just my one then
If the batteries drop below 6 volt that is what happens. I use Duracell and they last ages.
I have had three multi testers so far and found them unreliable!
They are over priced and over rated!
I will be going back to Meggar, tried and tested!
I agree. The Multi Function Testers are very unreliable. Had endless problems in several i have used. I find all of the other Fluke meters eg Voltage tester, multi meters all ok
Reply to Fluke Multi Testers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
I just had a look, and the Klein and the Southwire are both "True RMS" meters, whereas it appears the Fluke is not, as it says "averaging" against...
