Fluke product recall....... | on ElectriciansForums
Discuss Fluke product recall....... in the UK Electrical Forum area at ElectriciansForums.net
Baddegg
Supporter
Patron
Southsea
Anyone know what the turn around time is for the fluke voltage tester recall?
I thought with the internal battery and self test facility a Proving unit was not needed with the fluke Txxx series.
Just got my email and return info today. Turn round time for mine is no problem as I only play with it in the garage. I do dream sometimes of being out on the tools thought. So if I have an install dream while its away that could be a problem. I had a difficult one the other night. Dot and dab plasterboard and I had no fishing rods. (Probably because i was reading something on here about them at bedtime). Never finished the job so i hope i don't dream I'm back at that job again or I'll have to buy some rods to get a decent nights sleep.
But any self test wouldn't fully prove the device, in fact likely wouldn't prove the very scenario surrounding this product recall. Whereas the external voltage source is proving the device from one tip to another.
The self test is a tip to tip test. I believe the recall is due to a faulty termination on one of the leads. It can make our break depending on the position of the lead, giving a false negative. So, in this case, the test was as effective as any proving unit.
Reply to Fluke product recall....... in the UK Electrical Forum area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
Hi, Do you have the user guide. If not I will put the link at the end of the mail. May be worth checking that the meter has been set for UK usage...
