Fluorescent fitting to bright | on ElectriciansForums
Discuss Fluorescent fitting to bright in the UK Electrical Forum area at ElectriciansForums.net
N
nc12345
Hi Guys
Sorry this is going to seem like a stupid question but I installed a 600 x 600 HF 4 x T8 fitting today and the customer is moaning it's too bright , is there a way of removing a couple of tubes without them all going out ? I always thought if I removed one tube they would all go out.
thanks in advance
-What have you got for a cover, is it a diffuser or a reflector?
-Where is it, whats the nature of the space it lights up?
-Has it got control gear that can be dimmed?
-As in post 2 - can you remember the colour of tube, most now get stocked with white where as cool white (more clinical/daylight) and warm white(softer more homely) usually need requesting upfront.
Hi guys
The guy said they all go out
There is no control gear for dimming
I believe it's warm white or white , definitely not cool
Its has a metal diffuser
Its lighting up a kitchen in a shop
thanks
[ElectriciansForums.net] Fluorescent fitting to bright
When i do stage work we use filter gels ive used them in the past between 2 prismatic diffusers i cant remember the filter numer off my head but if you look at lee filters you should find them there
216 is full diffusion and I think 251 is half diffusion. It will certainly last longer than a month, probably a lifetime haha.
Seriously? Gel in front of fluorescent tubes, especially the cold white ones doesn't last very long at all.
Also diffusion filters are not for reducing light output, they are for diffusing it! To reduce light output you need neutral density filters which reduce light output by a specific number of stops.
The stuff we use last for the length we look after it. It only get binned when nobody can be bothered to pick it up off the floor. That's lee, 60 pound a roll. Yeah I know you'll need ND to take the hit off it. I got mixed up reading nick lake post, saw the word diffuser and numbers and thought that's what he was asking.
Reading again, he said he put gel I between a diffuser
Reply to Fluorescent fitting to bright in the UK Electrical Forum area at ElectriciansForums.net
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
