Fluorescent light | Page 2 | on ElectriciansForums
Discuss Fluorescent light in the UK Electrical Forum area at ElectriciansForums.net
H
hsharp
I wanted to change rose light for a fluorescent, but found going into the rose are 3 twin and earth and one single line, I disconnected it before taking note.
how do I wire the florescent up,I just thought it would be a case of finding supply and switch and wire usually.
I just thought it was a case of find supply and switch and wiring as usual.
The CB supplies an intruder alarm and the lights from this is 1 twin and earth and 1 single line.
I do not know what the single red is but it just comes out at the other to lights as well.
but at one light it seems to go into the switch which is 3 pole switch for light outside
i'll make a guess that that single red is a live feed to the outside light, and the neutral for it may come from elsewhere. if that is the case, then you really do need a sparks to sort it out. it's not a huge job. as said above, ÂŁ40-ÂŁ60 should cover it. a few forum members in yorkshire. sure 1 could fix it .
Reply to Fluorescent light in the UK Electrical Forum area at ElectriciansForums.net
I did consider this but ended up going with this one. I wired it inline with the lives and works great.
It would normally be the outer terminals where the flex of the pendant drop connect.
