Flylead to SWA without a banjo. | Page 2 | on ElectriciansForums
Discuss Flylead to SWA without a banjo. in the UK Electrical Forum area at ElectriciansForums.net
davesparks
I've been working my way through some EICR remedials in a theatre and one of them is to sort out a slightly high Zs on a submain.
Thankfully whoever installed it put the banjo on the gland and even put a bolt through it, they just didn't add a flylead, so its going to be relatively easy to fix that element of it. But it has got me wondering what could be done, or what other people might do if there wasn't already a banjo on the gland.
Obviously with most such situations you'd probably disconnect the conductors, remove the locknut and replace it with an earthing nut. But in this instance the cable is 400mm 4 core (I assume whoever designed this had never actually been on site and had to install a cable of that size or else they'd have split it into parallel cables, or they just hated the poor guys who had to install it) so there's not much chance of that happening.
I think if there hadn't been a banjo I would probably would have gone with something like a big earth clamp like you'd use for attaching lightning conductors to pipework and attached it to the main body of the gland. Something like this:
[ElectriciansForums.net] Flylead to SWA without a banjo.
And this is the offending gland:
I've never drilled into a 400mm cable though! (Not yet anyway) I'm assuming the cable is sized for high current handling not a really long 10amp lighting circuit!
Oh yeah, it's a 400A TPN submain of a fair length.
Technically you could say it's a lighting circuit though as it does feed the stage lighting dimmers!
I have cut some banjos not in half just to spring it around on some 185.0 but it isn't as easy as it sounds. We had to loosen off the gland itself and use that to tighten as using the lock nut just split the banjo out. There was a lot of cursing and cut fingers but you would never know they had been cut.
Interesting idea, I'll remeber that one.
It possibly wouldn't have worked on this particular one as what you can't really see from the picture is that the gland itself is behind a large trunking taking the outgoing circuits from the DB it feeds.
Reply to Flylead to SWA without a banjo. in the UK Electrical Forum area at ElectriciansForums.net
Hope everybody had a good Xmas! I crashed my car yesterday and in hospital still. Fractured 4 vertebrae, but not as bad as the one I did 12...
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
