A
adam.h
I have a neighbour who wants wall lights, they got some but there is not enough space to have either internal or external swa glands as the back box is small and the bulb fitting is right by the incomming hole for the cable. Also I have loads of 2 core swa so was going to use that to keep costs down for them. But if I can't use that then ho hum.
What I was thinking, as the supply end will all be earthed could I not crimp a few bits of the steel armour to a wire (or solder it) to connect to the earth terminal? Bit cowbowish I know, but I am not sure what I could do apart from buy 3 core, which if I can help it I would rather use up the stuff I have.
