Currently reading:
FOR SALE Electrcians tools and toolbox
Discuss FOR SALE Electrcians tools and toolbox in the UK Electrical Forum area at ElectriciansForums.net
M
mljc71
[FONT=&quot]All in virtually new condition on used in about a dozen jobs.
Milton Keynes or surrounding area- collection.
23” Stanley Fat Max tool box[/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]Ultra-strong structural foam, large capacity case with unique IP53 rated waterseal. ¾ length tote tray for easy storage of larger items.[/FONT]
[FONT=&quot]4 Piece Knipex Set:[/FONT]
[FONT=&quot]KPX0306180 VDE Combination plier[/FONT][FONT=&quot], The cutting edges are ideal for hard and soft wire, they are oil hardened and tempered, and then separately induction-hardened, with chrome-plated heads for smooth operation and handles with heavy-duty insulation for a softer, safer and more positive grip.[/FONT]
[FONT=&quot]KPX1106160 VDE wire strippers are[/FONT][FONT=&quot] made from a good quality special tool steel which is oil hardened for a longer usage live and better durability than some cutters in its class. They will cut solid or stranded wire up to a diameter 5mm or (10mm).[/FONT]
[FONT=&quot]KPX2616200 VDE snipe nose plier[/FONT][FONT=&quot] have long flat round jaws that are highly loadable, with elastic precision points with blades for hard wire diameter 2.2mm and medium wire diameter 3.2 mm.[/FONT]
[FONT=&quot]KPX7007160 VDE diagonal cutters[/FONT][FONT=&quot] are constructed from chrome vanadium solid style forged top quality steel with precision non slip tips for added strength and durability with high quality material and precise workmanship for long service life. Clean cutting at cutting edge tips - also in case of thin copper wires with narrow head style for use in confined areas.[/FONT]
[FONT=&quot]Stanley 0-65-443 FatMax Screwdriver Set Insulated Set of 6[/FONT][FONT=&quot][/FONT]
[FONT=&quot]Each FatMax VDE insulated screwdriver is individually tested to 1,000 volts .[/FONT]
[FONT=&quot]The soft-grip handle gives the perfect combination of great grip plus reduces fatigue and its large diameter offers greater torque needed for driving wood screws .[/FONT]
[FONT=&quot]Handle is moulded direct to bar giving a virtually unbreakable bond .Colour coded ends for easy identification of the right screwdriver for each screw type with a smooth domed end for fast spinning action, speed and comfort.[/FONT]
[h=1][FONT=&quot]Bahco 429-20 Claw Hammer Steel 20Oz[/FONT][/h] [FONT=&quot] [/FONT]
[FONT=&quot]Estwing [/FONT][FONT=&quot]Surestrike tack hammer with hickory shaft. [/FONT]
[FONT=&quot]Small 5.oz (140g) head for striking tacks. [/FONT]
[h=1][FONT=&quot] [/FONT][/h] [h=1][FONT=&quot]Stanley Composite Hacksaw 12"[/FONT][/h] [FONT=&quot]12" (305mm). Steel and plastic composite for increased strength and reduced weight. Constant 70kg tension. Soft-grip, bi-material handle for added comfort.[/FONT]
[FONT=&quot] Stanley 9" Magnetic Cast Aluminum Torpedo Level[/FONT]
[h=2][FONT=&quot] [/FONT][/h] [h=2][FONT=&quot]IRWIN JACK Plasterboard and Jab Saw Padsaw 165mm PLUS POUCH[/FONT][/h] [h=1][FONT=&quot] [/FONT][/h] [h=1][FONT=&quot]Bahco MTS825E Auto Tape 8m/26ft Reversible Magnetic Tip [/FONT][/h] [FONT=&quot]Metric and imperial scale on both sides of blade[/FONT]
[FONT=&quot]Flexible one way blade for measuring in tight corners.[/FONT]
[FONT=&quot]Stainless Steel Blade which makes the blade rust proof and washable.[/FONT]
[FONT=&quot]Totally Rustproof - Easy to read Nylon Coated Blade .[/FONT]
[FONT=&quot]Automatic Blade Lock for quick and easy measuring.[/FONT]
[h=1][FONT=&quot]Bahco Round ******* File 8"[/FONT][/h] [h=1][FONT=&quot] [/FONT][/h] [h=1][FONT=&quot]Bahco Hand Second Cut File 8"[/FONT][/h] [h=1][FONT=&quot] [/FONT][/h] [h=1][FONT=&quot]Bahco Wood File 8"[/FONT][/h] [h=1][FONT=&quot] [/FONT][/h] [h=1][FONT=&quot]Stanley 022500 6-inch needle file set (6 Pieces) [/FONT][/h] [FONT=&quot]Ideal for Model / Craft making[/FONT]
[FONT=&quot]Plastic Handles[/FONT]
[FONT=&quot]High carbon blade[/FONT]
[FONT=&quot]Added strength and durability[/FONT]
[FONT=&quot]In plastic Case Holder[/FONT]
[h=2][FONT=&quot] [/FONT][/h] [h=2][FONT=&quot]Stanley Folding Utility Knife[/FONT][/h] [FONT=&quot]One hand open/close for fast easy access[/FONT]
[FONT=&quot]Aluminium body - lightweight yet very strong[/FONT]
[FONT=&quot]Instant blade change[/FONT]
[FONT=&quot]Accepts standard Stanley blades[/FONT]
[h=1][FONT=&quot] [/FONT][/h] [h=1][FONT=&quot]Dewalt SGCPIO Contractor Pro In/Out Safety Glasses[/FONT][/h] [h=2][FONT=&quot] [/FONT][/h] [h=2][FONT=&quot]Megger MST210 BS1363 Socket Tester Overview[/FONT][/h] [FONT=&quot]Simple and effective identification of faulty wiring at sockets [/FONT][FONT=&quot]
Easy to use
2 green and 1 red LED’s for instant error reporting and fault diagnosis
Identifies 17 missing wire and wrong connection combinations
Rugged and reliable[/FONT]
[h=1][FONT=&quot] [/FONT][/h] [h=1][FONT=&quot]Fisher Satin Chrome Rule 6in / 150mm [/FONT][/h] [h=1][FONT=&quot] [/FONT][/h] [h=1][FONT=&quot]Fisher Fr112Me Steel Rule 12In/300MM [/FONT][/h] [FONT=&quot] [/FONT]
[FONT=&quot]Comprehensive tool belt[/FONT]
[FONT=&quot]Miscellaneous Items:[/FONT]
[FONT=&quot]Full set of NICEIC pocket guide.[/FONT]
[FONT=&quot]Sandpaper and sanding block.[/FONT]
[FONT=&quot]Pencils and metal sharpener.[/FONT]
[FONT=&quot]Grommets 20mm blind and open.[/FONT]
[FONT=&quot]Bradawl.[/FONT]
[FONT=&quot]Earth tape, masking tape.[/FONT]
[FONT=&quot]Miscellaneous screws and wall plugs.[/FONT]
[h=1][FONT=&quot]Also if you are a size 32/31 I have a pair of Dewalt Kneepad Work Trouser (kneepads required- about a fiver!) and Dewalt Knitted Hat Black.[/FONT][/h]
£200 ovno
Reply to FOR SALE Electrcians tools and toolbox in the UK Electrical Forum area at ElectriciansForums.net
