E
Engineer54
To be honest id on this occasion didn't go too deep as this job was designed by others but Clark of Electrical works expressed that only cables relating to the control side are allowed in the lift which generally is lift lighting and possible power points for maintenance as well as control loom to cab, i was informed supplies to lifts are not permitted to be run through the shaft in normal circumstances but due to the build and design of the segregated lift shaft and stairwell it is permitted.
I can only assume in normal circumstances the supply cables could become a fire hazard in themselves that in a shaft linking every floor is a safety concern or the very fact that the supply cables may generally require inspection and been part of the 17th would require a Electrician to gain access to the shaft which of course he is not permitted to do under any circustance without a trained qualified lift engineer.
Its not often im left to speculation but its not an area im often working in and thus means im not going to shell out the large amount of pennies needed to purchase BS EN 81-1 to give definitive answers so would gladly stand corrected if ive misquoted a requirement.
To note the whole extension was built to high fire safety standards even if the whole building attached went up in flames the contruction of the fire escape stairwell and lift shaft should see no propergation of the fire as its all concrete stairs and steel rail structure in a stone self supporting segregated build, only deliberate arson with a dumped fuel source could render the escape void.
I will be looking through our Spec on lift's installations later on today and come back to this thread. I will say now though, is that i have run lift supply cables in the lift shaft, the only stipulations as i can remember off hand, was that they were to be continuous with no joints or connections, and be provided with additional mechanical protected. Every passenger and patient lift on my projects have had redundant power supplies...
