found out electrician not registered midway through rewire | on ElectriciansForums
Discuss found out electrician not registered midway through rewire in the UK Electrical Forum area at ElectriciansForums.net
T
TrappedinTheWeb
Hi all
im a non expert homeowner and battling to understand the regulations. And apologies for the length of the post, a long story.
we have an electrician who came to fix a small issue few weeks ago. He seemed good. through discussion he ended up taking on fuse box replacement which we knew was needed and our previous guy had failed to come back to do. He said he could test and certify it when done but when the time came he said he couldn't because his tests showed the wiring was not right, and the house needed a rewire. It All seemed plausible and it is an old house we've recently bought, so not a huge shock to hear this.
We were under the impression the whole time that he was certified, through discussion about getting a cert and because he showed us a cert he had completed with test readings. We do feel he misled us into believing he was certified in some way although we perhaps should have asked for proof.
he is now half way through the rewire and the work to us looks fine, very neat,( though he's insisting that the sockets are placed 450 up under part m, which I now don't think is required in an old house). Had full faith in him until spoke to building control and transpired when directly asked that he can't certify for them and now ive checked and he also doesn't appear on nic eic either. I gather he should have told BC before starting the work which he didn't. So he's breached the regs, right?
we liked him but we think we can't possibly let him continue if he's completely unregistered and unregulated though he may well be qualified. We are worried about all sorts of risks; if it invalidate our insurance and he may not be insured either and we'd have no recourse if issues later. Are we overreacting and how do I broach this with him as he has no idea we are considering cutting his job short.? bC said they will come and certify it for a fee but not sure that's reassuring enough to let him continue.
grateful for any advice, feels like a very difficult situation and we're just not sure what to do.
I have left this in the main forum so hopefully the op gets a wider audience.
Get him to do it through BC if he is alright and knock off the price.
Sadly, how do any buyers of a specialist service, without some knowledge of the specialist service, 'know' if the person providing that service is 'alright'? 'Governing bodies' are there to assure those without knowledge that someone is 'alright' but many bodies require their members to 'purchase' a piece of paper. Over time it appears that where the people running the scheme profit from that transaction standards appear to slide; all the more so when those at the top of the scheme have little or no knowledge of the business that they are 'regulating'!
Thanks for the replies.
exactly as Kayak says, we think the work looks ok, but we don't have the knowledge to really know. And will BC be sufficient to know it is? He still has to wire the boiler and cooker, and the new circuits to the fuse board so some bigger items still to do, and I'm also worried that if anything goes wrong, he or we won't have any insurance.
would you let someone who is not part of any body or registered do this kind of work, or would you just say no way even if he'd already started?
It is sad GB Kayak has summed up the situation quite well, but that does not help you in this case.
You are quite correct for your refurbishment/rewire you are not required by the building regulations to have your sockets at that height so that is clear.
I'm afraid what I would do is basically ask him to down tools and stop work. Pay him for material and ask him to give you any outstanding material and tell him you are willing to pay for what work he has done once you have ascertained that the work meets the required standard, or offer him a small payment, and I'm sure he will move on, especially as you know he has not notified the Local Building Control.
Your in the south East there are quite a few lads on here that may take the job over and issue the proper certification for you. It may cost you a little more by doing it this way but you will have peace of mind.
nothing wrong with getting BC to check and sign the job off. the fee is around ÂŁ300. discuss it with your electrician and see if he's prepared to do this. an alternative is for him to get a scheme member to test and inspect it for him.
Just because he's not with the NICEIC doesn't mean he's not registered with another competent persons scheme. Also, if he's not registered at all, that doesn't mean to say he's not highly qualified, although the suggestion that sockets have to be at 450mm leads me to believe that he's a classic 'old wives tale' kinda spark. Without more detail, I can't really comment.
One final thing to add. It is the responsibility of the Homeowner to notify Building Control, not the electrician. Being a member of a competent persons scheme just makes that process easier and cheaper.
Where abouts are you in the South East?
Just because he's not with the NICEIC doesn't mean he's not registered with another competent persons scheme. Also, if he's not registered at all, that doesn't mean to say he's not highly qualified, although the suggestion that sockets have to be at 450mm leads me to believe that he's a classic 'old wives tale' kinda spark. Without more detail, I can't really coomment.
I've always thought the onus was on the homeowner to notify too. I was speaking to other sparks about this and they said I was talking rubbish. Do you have or know of any links that say so Damien? Just to prove my point. Cheers
It's all to do with the interpretation of 'the person carrying out the work' which, in the building regulations is interpreted to mean the person responsible, the person enlisting the services of others to do that work. It's always the Homeowner who will be served an enforcement notice for this reason. Part P of the building regulations is a small section at the end that stipulates really that whoever is doing the electrical work needs to make sure it's safe. That's it! Approved document P (an entirely seperate document to Part P of the building regulations) comes along and muddys the waters somewhat. Approved document P, the one we've all actually read, and are required to have in order to join a scam scheme, is nothing but guidance on how to ensure you meet the requirement of the Building Regulations - Part P. We are under no obligation to follow Approved Document P, it even states this somewhere in the first few paragraphs, as there are other ways you can demonstrate compliance with the Building Regulations. Local authorities are often the first port of call to those who want to demonstrate their compliance with the Building Regulations in other ways.
The main problem is that people are often confused between Approved Document P, which is non-statutory guidance, and the Building Regulations - Part P, which is statutory. When looking to define legal interpretations, it is the latter (as a whole) which needs to be turned to.
Thanks for all the replies.
Now I am confused since I was reading the Approved Document P. But that does seem to quite clearly say at 3.8 page 10
'If an installer is not a registered competent person and has not appointed a registered third-party certifier, then before work begins the installer must notify a building control body'
http://www.planningportal.gov.uk/uploads/br/BR_PDF_AD_P_2013.pdf
I would have thought the 'installer' means the electrician, though perhaps it's not binding as it's not the Regs themselves?
In any case, part of the point of hiring him was that he was holding himself out as someone who really knew the regs (and that he could give us a cert) and I would have expected, as part of the service that he advise us explicitly that he is not registered and we need to tell BC, if he was not doing that himself. He either knows the regs and ignored them, or chose not to mention what was needed in terms of certification (even though we had long discussions about that) or doesn't know the regs - and neither is great tbh.
If we do say to stop work I am not sure what is reasonable to pay him for what is done so far. has has put in the wiring and cavities for the lights and upstairs sockets already, but we still have the original circuitry working so can live in the house with it until we can get someone else, if need be.
Re whether he is part of another body other than NICEIC - Yes completely see that point. If you can tell me what registers to check I will check if he is listed under another, but he's not appearing in any I have checked so far (I wish I had done that before hiring him - lesson learned!). And the company name he gave us is listed as 'dissolved' on Companies House.
Thanks again for all the replies so far . Useful to get views from you all as we don't know how it would be from his PoV.
TTW, ask him which scheme he is registered with, if any. If what he has told you is proving false then perhaps the best thing to do is to put your investigations and concerns to him and if he does not have satisfactory answers to your questions then show him the door. A key question is what regulations he is working to and whether he has a copy, ask him to show you it. The answer should be BS 7671 and he should show you a book ~ A4 in size and about an inch thick with a green or yellow cover; ammendment 3, yellow cover, came out in Jan this year and installations must be in accordance with it from Jul. Even this doesn't necessarily help, because he may have a copy but not be able to interpret or use it!
If he's a sole trader then he wont be listed on Companies House. Is he trading as a Ltd company?
There could be an innocent explanation, like he is registered with Napit or Stroma and is trading as a sole trader, and you wont know until you ask him.
Also, you talk about regs and certs and this could be confusing as there are wiring regs and building regs and electrical installation certificates and building regulations compliance certificates. He will be able to give you an electrical installation certificate regardless of whether or not he is registered with a part P scheme, but he wont be able to give you a building regulations compliance certificate if he is not registered.
One of the problems with the approved document, is that there are a number of requirements listed that are not statutory requirements listed in the legislation.
Although the Approved Document states the installer should contact Building Control, there is no statutory requirement for them to do so in the legislation.
In the approved document, only the parts with a green background are Statutory Requirements.
Also I think this may vary by Local Authority area but if the person carrying out the work can 'demonstrate competence' - i.e. proof of qualifications/experience as well as submitting a correctly completed certificate then costs can be reduced depending on what,if any additional inspection they feel is necessary.
Reply to found out electrician not registered midway through rewire in the UK Electrical Forum area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
2 3
