FP Cable Is Not Always Suitable
Take it to work and IR it mate, just out of interest.
I did take the other one to work and did ir it, got about 60Mohm.
to be honest I didnt cut any off coil or try to get any moisture out of it first before I made end of so who knows.
this one should have a lot higher reading?
it was a little odd because it fluctuated from 50mohm to > 299 at 500v. im guessing batteries in tester could be low because didnt get constant reading
or there may be a slight bit of moisture there and the IR test is drying it out, thus readings will rise as you keep the tester on it.
The correct method of IR testing a new circuit/build is by applying the test voltage for a minimum of 1 minute... Most electricians, will if you're lucky IR test for 10 to 20 seconds. lol!!
Tut. tut!! They don't seem to be teaching much at all at college these days....
they only teach the questions/answers that are in the exam now, only reason I didnt need any resists in final year was I studied off my own back online.
everyone else needed a resist or really struggled.
one question in jtl test was how deep is recommended for a bore hole for the average sized house.
no mention in revision books etc that we were supplied with etc and even tutors were clueless when I mentioned it after exam
thought a bore hole was where you put the father-in-law when you couldn't take any more of his verbal diorrhea.
tazz,
telectrix,
TrueNAS JBOD Storage Server
