Stroma Certification Scheme Fraudulent Certificate
I agree with Mike & Snowhead, the dispute is between yourself and the seller, this is clear.
Having said that the electrical issues seem minor and would only take a couple of hours to correct, so if you allow a day and some materials you are looking at £300 or less to get a safe installation.
With that in mind, I’d instruct my solicitor to write to the seller a letter explaining that he/she has committed fraud, outline why and demand say £500 to correct the defects to stop further proceedings. I don’t think I’d take it any further than that due to cost, but I think you would more than likely get a cheque through in a few days.
Looking at the certificate I don’t think that you have a particularly dangerous installation, the test results seem okay and you have a newish metal consumer unit, which is probably the addition/alteration that’s 1 year old. Might be worth asking for that certificate but I’m sure if the seller had one they'd have supplied it.
I like and agree with this post, but get an actual quote first and add any redecoration that will be needed as a result of works done.
The fist report is abysmal the second very thorough.
There are a lot of observations, some duplicate the same issue, but not a lot of cost in putting it right.
Just a lot of tidying up really.
However your dispute goes with the seller I can't see that lot coming to more than a days labour and £20-30 in parts.
You could go further and argue that you purchased thinking the wiring was 3 years old as per the certificate, indicating it had been rewired recently........the seller/person ordering the report should have at least read the report and queried some of it, obviously to a layman the test results are gibberish but age or wiring is pretty simple and if they lived there longer than the stated 3 years they would have known that to be false or a mistake...
Looks like the seller definitely got their £60’s worth of inspection and testing on that first report...??
This is the trouble with people going with the cheapest option, what they’re getting is a load of sh1t3 for their money that’s not worth the paper it’s printed on.
We all know how long it takes to complete a thorough inspection; and that’s what we should be doing and charging accordingly.
when I quote for EICR’s these days, I let the client know roughly how long it should take and warn them that anyone charging substantially under will be done in 40 minutes and won’t have tested bugger all.
If the CU is only a year old, what retard puts all the circuits on 1 RCD ?
Did you get anywhere with this @ebrcknrdg ? Would be interesting to know if Stroma decided to act?
Hi
No stroma weren’t interested at all. In the end the solicitor wouldn’t help either because there was a conflict of interest due to the seller using the same solicitors when selling the property. So I came to an agreement with the seller himself whereby he covered the cost of the repairs
Glad you got this sorted, but does the solicitor need reporting to their professional body for not representing their clients interests or miss conduct?
I tried contacting the SRA who weren’t very helpful either! I signed a form regarding the conflict of interest when purchasing the property so it seems i signed my rights away. Lesson learnt on many levels
Notwithstanding you signing a form, this does not diss-charge the solicitor from performing in a way to represent his client in a professional manner and in accordance with the conveyancing laws, the SRA will not be keen to take on a complaint unless you put it in writing, ask for their complaints procedure documentation or if available a complaints form.
Hi
Good for you, glad it's sorted ?
ebrcknrdg,
Soi disant,
